06-06-2017, 09:26 AM
(05-06-2017, 03:24 PM)pwdrive Wrote: The way the valve is graphically represented in the Philips valve data sheet sums it all up.
Yes and no.
To me, the clearest symbol is the one produced by Mullard and I have a copy of a data book around somewhere but not easily to hand at the moment.
The point is that there is no absolute standard here - thus the blobs for the cathodes in some European versions - or even the layout.
The clearest versions, in fact, show only two cathodes which simplifies the symbol and relates to the two separate cathode pins: see here and here.
Even clearer are symbols that disregard the pin layout but just show pin numbers for each electrode, thus eliminating all the connecting wire floating around inside the symbol.
To me, the important points about any symbol in a diagram are simplicity and clarity. Remember, we only need to know how the valve works in practice, not the finer points of its construction.
If you disagree with that, why not include the mica supports, getter and anything else you can think of!
