16-04-2013, 09:30 PM
(16-04-2013, 09:13 PM)AlanBeckett Wrote:(16-04-2013, 08:39 PM)pwdrive Wrote: .... note the frequency displayed on the SSB transmission ....
Arrrrrrrrr.
So it's got a lot of digits.
But how accurate is it?
Alan
Alan, so far as I can ascertain from the manual, it's as accurate as you set it when in calibration mode eg: you can compare and set it to a known accurate frequency eg: a WWV time signal, calibrate it to that and that's it, I assume that once calibrated then from that point on it is referenced to the clock and would only be subject to errors caused by thermal drift within the clock Xtal, which I would think would be very low, unless I'm reading the book of words wrong.
Lawrence
