05-03-2013, 04:07 PM
Hi,
Thank you Tony for adding such kind comments regarding my work. At times I thought this job was getting away from me and on a number of occasions it looked hopeless and irretrievable but the harder it became the more I dug in.
The veneering was definitely the hardest part of this restoration but with my newly gained experience Burr Walnut now holds no fear for me. I found that soaking the Burr with water both sides then hot ironing not only flattened the burr but rendered it pliable whereas this Burr whilst dry was extremely fragile and brittle.
Cutting the Burr to slightly over-size whilst the Burr is wet and ironed means it can be laid once using hot hide glue and hammer; tape the joints and if there is a possibility of the edges of the Burr lifting as it dries out prevent this by either mechanically clamping or taping then allow the cabinet to dry out slowly before removing clamps/tape. Trying to remove the dry tape by scraping is a real pain but simply wetting the tape quickly releases it without effort; it doesn't require a good soaking so any water applied will quickly dry.
Usually when I'm French polishing (Shellac) I go for the very high gloss (mirror) finish after all this is what is associated with French polish but I hope the finish on this Barker demonstrates that French polish can be finished to any degree of shine from dead Matt to gloss. To achieve the gloss finish using French polish is time consuming but the finish (satin) on this Barker was rapid; all I did was to apply a good thickness of French polish using a fan brush then I flatted using 1000g abrasive paper lubricated with Talcum Powder; give it a good dusting off then apply liquid paraffin with a cloth and finally buff to reveal a truly wonderful finish in keeping with a cabinet of this age. It really is that simple.
Had the weather been decent I could have completed this restoration in a fraction of the time but the weather tries to ruin my enjoyment; today has been dense cold fog and at 3.30pm the sun finally broke through but I still cannot see the other side of the valley as I type because the fog is lingering. The workshop to the rear of the bungalow is perishingly cold but tomorrow I'll turn the heating on for a session and blow the weather.
I would encourage anyone to have a go at producing this finish as it is so easy but looks expensive.
Kind regards, Col.
Kind regards, Col.
