Yesterday I started looking to see if I could find a reason why the transformer was running 'hot'. Mains input after the dropper is 216v and connected to the 220v tap so all looked ok there. Voltages and currents looked within spec. I started ohming stuff and found the mains on/off switch was dodgy. When closed the resistance never went to zero and would vary from 40Ohms to to around 400Ohms when the contacts were 'jiggled'. Since it is impossible to do anything with it in situ I figured there's nothing else for it - the switch has to come out.
Getting it out was fun but I got it out in the end. I did all the spraying and cleaning I could and I got it much better but still not 100%. When closed it would go to zero Ohms but still subject to variation when the connectors were moved.
Since it is a custom switch I figured I had no choice but to re-fit it and hope for the best. As I tightened the mounting nut the switch suddenly cracked down on side and various internals flew out!
So, I'll confess to some non-seasonal expletives at that stage! Having now calmed down (the morning after) I've ordered up some switches that are similar to this one but of course the special switch lever shape will need to be replicated. Oh well - one must remain detached!
Cheers, John
Cheers, John
