18-05-2015, 01:51 PM
Anyway, back on the job.
Mundane stuff first - Cables. These connect the PSU to the other Modules.
There appears to be two types - Long ones to connect the PSU to a Module and short ones to loop between the Modules. They look to be in reasonable nick and they buzz out OK so onward and upward, except that I'll have to make some more.
Now the 162 Waveform Generator.
It's a neat little unit with no Covers. I don't think they're missing because none of the others have any. There are only 6 Valves although most are Doubles. There's one double Electrolytic which will bear keeping an eye on. By the way, the bend in the Front Panel isn't the Camera, it really is there. Everything seemed clean and unstressed and all the Controls moved. A judicious application of Switch Cleaner seemed in order and a check of the Valve Pins.
So, fire it up with the Controls set to what I hoped was something sensible and see what's coming out.
The best I can say is a complete shambles. The Waveforms are awful and the Controls seem to have very little effect.
So, I've left it on soak while I RTFM.
Alan
Alan
