06-05-2024, 08:20 PM
Hi Rob, simplest way for heaters is to use an LV bench power supply which is normally both regulated and stabilised.
If you can get an old Farnell E350 ? these are HV stabilised lab supplies and quite small. This takes care of the HT as well
It is also quite easy to knock up a simple valve HT stabilising circuit if you are worried about mains variation
Cheers, Ed
Cheers, Ed
