09-10-2014, 09:25 AM
found info for SM1 used Tuner VALVES USED ARE 1 X ECC84, AND 3 X ECF80
Rogers Tuner info needed
09-10-2014, 09:38 AM
(09-10-2014, 09:25 AM)FIXITNOW Wrote: found info for SM1 used Tuner VALVES USED ARE 1 X ECC84, AND 3 X ECF80 Damn, I was just about to suggest an ECC84 for the front end based on your pics. ![]() Lawrence.
09-10-2014, 10:00 AM
found a post on another radio forum where the guy has one and was looking for a circuit(sadly there was no reply)
but have PMed him asking about the valves and for pics of his unit hopeful he may be able to help
09-10-2014, 10:09 AM
(09-10-2014, 10:00 AM)FIXITNOW Wrote: found a post on another radio forum where the guy has one and was looking for a circuit(sadly there was no reply) That valve line up sounds something like eg: pentode anode for ECF80 is pin 6 (EFxx pin 7) you could always fit the missing res/filter cap stick them valves in and see what happens. Lawrence.
09-10-2014, 10:19 AM
If you can't get a schematic you should be able to do some reverse engineering to get one, the chasiss doesn't look too complicated.
09-10-2014, 10:57 AM
Page 46 of this magazine gives a brief description of the valve functions of a Rogers switched FM tuner which could be similar to Vince's, the cathode follower theory seems to be born out:
http://www.americanradiohistory.com/Arch...959-03.pdf Lawrence.
09-10-2014, 12:02 PM
(09-10-2014, 10:57 AM)pwdrive Wrote: Page 46 of this magazine gives a brief description of the valve functions of a Rogers switched FM tuner which could be similar to Vince's, the cathode follower theory seems to be born out:good link thanks
09-10-2014, 01:07 PM
Looks as if the main smoothing capacitor is missing as well. Presumably the wires by the large hole at the rear end should go to the missing cap.
Keith
09-10-2014, 01:10 PM
(09-10-2014, 01:07 PM)Keithstv Wrote: Looks as if the main smoothing capacitor is missing as well. Presumably the wires by the large hole at the rear end should go to the missing cap. yes it is will need to find a suitable one and find its value/voltage plus I guess there will be a resistor between the 2 plus ends there are 4 wires so I guess it was isolated (09-10-2014, 10:57 AM)pwdrive Wrote: Page 46 of this magazine gives a brief description of the valve functions of a Rogers switched FM tuner which could be similar to Vince's, the cathode follower theory seems to be born out: scan from the mag to save all downloading as a large file and so it is always here |
