24-02-2017, 02:11 PM
This might be controversial, but...
If you want to learn about how transistors work, forget about old text books. They are next to useless in my experience (happy to be pointed towards an exception). They were written by people who were too stuck in the valve era and didn't really understand how to apply them (fair enough, in a way), and spend far too much time banging on about physics. None of that helps you to understand what's happening in a radio.
I'm not dismissing the physics out of hand, but I've never understood how that helps beginners - I suppose the academic argument is to create a bridge between something you already know and something new, but why assume that a budding electronics engineer is already a highly qualified physicist? But while I find the physics is really useful for understanding some of the more obscure stuff that comes up later (e.g., Early effect), I'd really advise you to forget about holes and electrons, and focus on what the transistor actually does for the time being. Come back to the physics later if you like, but it's not essential, even for quite advanced circuit designs.
There are lots of modern text books and web sites that give good explanations. Start by downloading this: http://wouterjan.deds.nl/The%20Art%20of%...20Hill.pdf (it's about 27MB, but worth it!)
Fundamentally, transistors appear to work in two ways:
1. The current control method. A small base current controls a larger current in the collector. Look up "transistor man" on page 64 of that PDF.
2. The voltage control method. How it really works. The voltage between base and emitter accurately determines the collector current.
Sadly, many people believe that the current control method is the way transistors actually work, and you will encounter many arguments on forums to that effect. Many text books also assert that. Sure, when you apply a voltage to the base-emitter junction, a current flows, and that current is roughly proportional to collector current. The ratio between the two currents is called Beta, or hfe. But Beta (or hfe) is a very poorly defined parameter that varies between device sample, temperature, collector current, planetary alignment, etc, etc. Whereas the theory that drops out of the voltage control approach is dependable and precise - much more believable and useful.
In practice, you need to think about both when analysing and designing circuits. But you treat the current control method with the caution it deserves, and avoid designing circuits that require a specific value.
The PDF covers a lot of ground that can be skipped at first, but goes on to discuss the voltage-control method on page 79. It introduces the Ebers-Moll equation, and gets to the point that the transistor is a transconductance amplifier (voltage in, current out - just like a valve). For a transistor, the transconductance - gm - is simply 40 times the collector current. Knowing that, it's really easy to understand (and design) transistor amplifiers.
Another really good book is here: https://books.google.co.uk/books/about/A...edir_esc=y
A lot of our electronic fundamentals training here at work was based on this book. I'm not aware of a PDF download, but the Google preview gives you a flavour.
I appreciate that this post will take some digesting, but if you want to fix transistor radios, you need to start at the beginning (but skip the physics!). I'd recommend doing some experiments using a breadboard, but whatever works...
