12-02-2015, 12:47 PM
I was similarly impressed when they came out to replace the "head" (what do they call it - the thing with their fuse at the end of their cable?). They took away the lovely cast-iron lump with a 30 amp fuse (just a bit of wire) and replaced it with a modern plastic box with a 100A fuse. When I asked if such a large leap was OK, they said that my incoming cable was good for double that! It was impressively thick, and it's not a long run back to the sub-station.
Before changing the end, they isolated it by digging up the cable in the front garden and carefully peeling back the layers. Overall, the cable is between 1 and 2 inches in diameter, and beneath the multiple protective outer layers (mostly of something that looked like cloth soaked in bitumen) as a spiral of what looked like steel - quite thick - that carried the earth. There was paper under that, IIRC. Inside that was a very chunky twisted pair carrying L and N. The N-E connection is back at the sub-station, which makes my supply a nice TN-S type.
I've no idea how old this cable was, but the house is Victorian. They said it could easily be 1930s...
Once the head was changed over, they used one of those resin-based splicing kits. Again, very impressive - and massive. Proper engineering
Fortunately, the weather was good, and no umbrellas were needed!
