dont like to get rid of any thing but i must start i also now have a digital one but its complex to use also a digital sat meater
trouble is im gettig to old to climb up roofs
here is what i use nowadays but not if i can help it
I could really do with one of those for a short while to check my buildings feeds.. they don't work as well as a bit of wire hanging in the back of the box at the moment.
The post here is a menace.. but I'm next door to the sorting office I was thinking about the first one.. the boot sale beastie.. I find it hard to get my analog head around digital readouts. If you price it up I'll even consider buying it.. I can always sell it on at cost afterwards to another member.. They do work fine on the digital muxes if all you are after is a straight idea of the panoramic field strength around the aerial.. or as in my case.. proof the communal aerial system isn't working.
i will have to check that it still works as you can see its led a hard life if it does you may have it for the cost of postage as i say i must get rid of some stuff the owner of the shop i worked in just past away and there seams to be stuff there that used to belong to me, some one eles who could not get rid of any thing
rob t
That sounds good to me.. thanks. My communal aerial system is certainly not working.. I'm getting better reception from 6 inches of wire hanging out of the back of the box. It's annoying only having 6 channels considering that from the window by the lift I can see winter hill about 9 miles away.
(28-03-2011, 12:09 AM)Paula A Wrote: That sounds good to me.. thanks. My communal aerial system is certainly not working.. I'm getting better reception from 6 inches of wire hanging out of the back of the box. It's annoying only having 6 channels considering that from the window by the lift I can see winter hill about 9 miles away.
UhOh communial aerials!
We live on a housing estate with flats on it, while I live in a private house you'd be amazed at the wonky aerials and clumps of coax wire dangling from flat roofs!
