11-06-2014, 06:55 PM
Also, with a correctly wired mains plug on this type of design of AC/DC set plugged into the mains:
If the neutral pole of the mains switch is open circuit in the on position (eg dirty contacts etc) or the neutral connection between the mains plug and the chassis connection has gone open circuit or high resistance for whatever reason then it is possible that the chassis could be potentially lethally live when the set is plugged into the mains and switched on even if one of the valves has an open circuit heater.
Mains Isolating transformer.
