05-05-2024, 06:54 PM
(This post was last modified: 05-05-2024, 06:56 PM by ppppenguin.)
Split from https://golbornevintageradio.co.uk/forum...p?tid=9110
In principle you can test a valve with a number of variable power supplies and a number of meters. How many you need depends on the type of valve. You also need a means to connect all these to the correct pins of the valve and try not damage you or anything else while you're doing it. There are also important refinements like making sure the valve doesn't decide to oscillate at some un (insert $deity of choice) ly frequency.
The rest is detail and convenience. From the simplest vintage valve testers to a Tektronix 570 curve tracer they are all making these measurements. With greater or lesser accuracy. With greater or lesser convenience. With greater or lesser detail. Slightly off to one side is the uTracer: https://www.dos4ever.com/uTracer3/uTracer3_pag0.html which uses the cunning trick of pulsing the voltages on the valve's electrodes. This comes with its own set of advantages and disadvantages.
Then there are all the things a valve tester won't tell you such as high frequency characteristics and pulsed power performance.
A big and interesting subject.
