27-03-2021, 02:39 PM
Just been doing a little more work on this and I have noticed that with a 525 line source the the output looks a little woolly when compared with a 625 line source.
With a 525 line source some artefacts can be seen before and after any vertical lines. Horizontal lines are not affected.
The source that I am using is a test card from another Hedghog PSC. Viewed on a monitor the 525 and 625 line test cards look equally good and sharp.
I know that this test card can be a bit harsh but it is not causing any problems at 625 lines.
As it is only vertical lines that is effected what ever is causing this must be in or around the decoder.
The converter should only effect horizontal lines.
It does not photo easily but I have tried. Photo below.
Frank
Frank
