20-07-2020, 11:25 AM
(20-07-2020, 09:58 AM)Bushbaby Wrote: I did set the oscilloscope probe to x10 as was indicated. I ddo have to say that the T935a volts/div setting is hard to interpret. The manual indicates that the reading must be taken from the x10 (I assume the light grey) slot on that side.
On most older and simpler scopes you just get the basic V/div setting on the knob. You then allow for the x10 probe in your head. So 2V/div becomes 20V/div. This scope shows you the basic and x10 settings which saves some very simple mental arithmentic.
Some more sophisticated scopes with on-screen readouts work with probes that indicate to the scope whether they are x1 or x10 and always display the sensitivity at the probe tip. I think some others, possibly including my Rigol 1054Z, have a user selectable setting for probe type so that the on-screen readouts are correct. Less sophisticated than automatic probe sensing but doesn't need special probes.
