25-03-2018, 08:29 AM
Hi.
Thanks for the info Steve.
Some of the changes appear to be very small and I wonder if the customer or even the engineer would have seen any notable changes on screen or the way the receiver operated after these alterations?
Today i believe we are blessed with very good standards converters for our hobby through the work of dedicated people like Darryl & Frank
So far I would like to add this.
Hedghog........
Good points:
Excellent conversion
Accessible front switches
Cool running
No motion artefacts
Covers all Band one & three channels.
Switchable Aperture (2, 3 & 6 line interpolation)
Switchable audio test tone, off, 400Hz, 1Khz.
Conversion video output
Not so good points.
PM5544 internal test pattern, not a big issues though.
Unable to program a user test image.
No audio level control.
Not useable as standalone modulator
The advantages out weigh the disadvantages though and overall the converter is a very competent.
Aurora SCRF converters.
Good points.........
Small size.
Tried and tested over many years
Test card C stored image
Can be programmed with user test image
Audio level control.
Good conversion with only very occasional motion artefacts.
Availability of NTSC 405 line colour..... to order!
Can be used as a standalone modulator
Not so good points.
Fiddly dip switches on early models and even more fiddly setting up on later types
Slight HF rolloff that gives the picture a very slight flat appearance.
Runs warm in the smaller case.
So not a lot to choose being fair, both do a very good job.
My own summing up and of course is my own opinion is the Aurora is well known and has had a tiny amount of failures often caused by the operator, it is compact and easy to use, to my mind the small disadvantages are not a big problem, but I am making observations.
The Hedghog being the new kid on the block as yet has not been around long enough to test the reliability, I suspect though it should be as reliable as the Aurora. I particularly like the front switches, which are much easier than the DIP switches in the Aurora that means opening up the case, switching the test pattern on or off on the Hedghog is also an advantage rather than removing the video or audio leads or the signal on the Aurora, so the Hedghog can be more or less left in place whereas the Aurora may have to be moved more often. This is pretty minor being fair but the Hedghog is a little more user friendly.
Like I've said, subjectively the Aurora does look a little bit more flat than Frank's Hedghog, certainly I never complained before and I'm still not complaining, where you do see the difference is on a bigger screen with a set that has good alignment and the difference is notable.
Finally I'd say the Hedghog has the edge, weighing up the user switches, the aperture switch and a slightly less flat picture that is my reason, yes there is a few small niggles in the Hedgehog but being fair nothing to really cause concern.
I will be running both converters on a regular basis and any reliability issues or problems and I will post up.
Again many thanks to Frank for his generosity with giving me the converter.
Hedghog........
Good points:
Cool running
No motion artefacts
Not so good points.
Small size.
Not so good points.
Cheers.
Trevor
Trevor
