11-09-2017, 07:03 PM
(This post was last modified: 11-09-2017, 07:08 PM by ppppenguin.)
The difference between 2 and 3 line interp isn't big. One day I must do some coefficient sets for 3 and 4 lines and see the difference. My own converter has a 4 line interp but I've only ever used it at 2 lines. According to BBC work, there was very little difference between 3 and4 lines but significant difference between 2 and 3. While you can definitely see that on test card you'd be hard pressed to see it on pictures.any set that can resolve the scan lines will show the interp quality. You don't need good horizontal resolution.
8 bit coefficients and 5 bit sub line position are amply good enough.
